What is the maximum value of Vref in PIC16F877A?
thiruatmail
Newbie level 1
hi frnds...what is the maximum value of Vref.....can we fix it as 12 volt dc..........tku
mouzid
Full Member level 5
Re: PIC16F877A
Please elaborate.
if you mean Pic's Power supply it is 5 Volt.
VVV
Advanced Member level 5
Re: PIC16F877A
No, you canno do that. Check the datasheet and you will see that the reference voltage has to be lower than the supply voltage, so the maximum reference is 5V, even less if your power supply can drift.
laktronics
Banned
Re: PIC16F877A
Maximum value of Vref. = Vdd, So, you can not use 12V Vref.
Regards,
Laktronics
