What is the maximum range of RF transceiver module available in India?
binojkumar
Full Member level 3
Bangalore
Hi friends, what is the maximum range of RF transceiver module available in india (BANGALRE) . Im looking for a 1 km Range.
VC
rf transceiver how to figure distance range
VC
Unless you are a license holder, you would, i fear, be in the hands of Police in no time you start transmitting. why such long distances and how you plan not to interfere with others or get interfered by others.
rf maximum range
What type of data you want to transmit over such distance? Is it Audio, Video, analog or digital?
Please be more specific.
rf transceiver for digital audio
Not sure what you can get in Bangalre <sic> but XBee makes long range RF modules.
digital rf transceiver modules
It is 1 km range remote control, im sending digital data only.
microcontroller rf transceiver
Since you are going to transmit data only only, therefore I think that a simple FM transmitter can do the trick.
Check the below website, there are several of FM transmitter those can cover the required range.
All you have to do is to encode your data before applying it the transmitter.
I hope this helps.
rfid transceiver long distance
Hope you are refering TLP modules working on 433 Mhz. These will have maximum range of 100 Meters in open space. For transmitting for more distance, you need more power and for that license from Wireless planning and co-ordination wing (WPC) Dept of Telecommunication, Govt of India.Delhi. Good luck
transmitting digital audio over a rf transceiver
I am of the opinion that the same signal instead of broadcasting, if could be beamed, it will cover longer distance. Of course, one has to design small directional antennae for Tx and Rx both
