What is the manhattan routing ?
buenos
Advanced Member level 3
Florida, USA
hi
what is manhattan routing?
are there other similar things in PCB design with this kind of fantastic code name?
pcb manhattan distance
It isn't Manhattan routing, it's a way of measuring length for a routed trace. The Manhattan Distance is the distance measured between two points by following a grid pattern instead of the straight line between the points. It is also sometimes called the "Taxicab Distance". It gets its name from the way a taxi has to drive following city blocks (like in Manhattan, New York, USA) to get between two points. See https://mathworld.wolfram.com/TaxicabMetric.html
The relationship to PCB routing comes from the fact that most autorouters follow the defined grid when trying to find the shortest distance between nodes on a board. Some EDA packages let you display the Manhattan Distance between two nodes. It's a way of checking the length of the routes.
manhattan routing
If you wanna know about Manhattan Style of PCB construction read this article.
LRIOS
