What is the initial value of DFF if input is fed from output
leongch
hi,
i am trying to do the a frequency divider by 2 by using the DflipFlop
The design just simple where the output of the DflipFlop is feedback to input of the DFF... While i run the compilation the ALTERA QuartusII not allow the input to be feed directly from the output. Anyway to solve this kinda problem? Thanks :p
Oh... by VHDL ... [/img]
You should add a revert before feedback the output. And you should reset the flipflop.
Nandy
www.nandigits.com
Netlist Debug/ECO in GUI mode.
ops...sorry, the feedback loop going to hv a inverter...
Nandy, just to clarify, do u mean, we first reset the flipflop first then the output will be LOW (0) can cause the input to be '1' ?
Re: What is the initial value of DFF if input is fed from ou
hi
Small error dude jus take it from QN and feed it back to D.. u will get it..
But getting to ur q : connect Q to D then it would be controlled by S and R pins..
