Impulse C & co developer is a new tool for designing digital system in pure c coding style.
You do not ave any need to worry about timing.
It just takes your c code with modifications to be accepted by Impulse C compiler.
You choose your target platform & it does the whole thing for you.
The software parts are converted to the target processor while the hardware parts are converted to hardware.
you then take these files & synthesize them & get your circuit.
You only need to verify your c code. This can be done by Impulse C itself or any C compiler as VC++ or Borland but after including the Impulse C library.
You better see its site.
PS. There is a book called programming FPGA in C in edaboard its useful.
