What is the effect of varying the gate length in both AC and DC characteristics?
protonixs
Full Member level 3
Full Member level 3
PH
In CMOS, what is the effect of varying the gate length in both AC and DC characteristics?
Does it affect the current-carrying capacity of the device?
Thanks and regards,
protonixs
Re: gate length
it affects and we all the know that drain current is inversely proportional to length... but in fabs the length is generally a fixed value... it affects the AC and DC parameters because change in length changes the capacitance and resistance too...
gate length
This is my little 2 cents.
The drain current is proportional to the W/L ratio. Therefore, it is a better practice to just adjust one parameter, and i guess the common practice is to keep L at minimum level and adjusting W accordingly.
varying the gate length will definitely change the AC and DC characteristic. I do not have any references with me at this moment so I can't provide any details about it.
Back to your problem, I think the answer is Yes, it will affect the current-carrying capacity of the device
Hope that helps,
Re: gate length
For DC affect Vdsat, for AC affect gm, rds.
Re: gate length
leaving a constant W, increasing/reducing the gate length reduces/increases the current that flows from source to drain, is that right?
