What is the difference betwen standards and protocols ?
sivamit
Full Member level 4
What is the difference b/w a standard(e.g RS232) and a protocol(e.g SPI) ?
Re: standards and protocols
I think, Protocol refers to a sequence of operation and Standard gives the specification of the system. So, a standard may or may not contain a protocol.
Regards,
Laktronics
sivamit,
laktronics is correct. For example, the RS232 spec defines voltage levels for 1s and 0s (referred to as "space" and "mark") for the Rx (Receive) and Tx (Transmit) lines. It also defines levels for various control signals, such as CTS, RTS, etc. It also defines a connector and pin assignments. However it does not mention how these signals should be used (the protocol). On the other hand, the Firewire (IEEE1394) spec defines both the electrical specs and the protocol.
Regards,
Kral
