What is the difference between Unix & Linux?
mamun9024
Newbie level 1
What is the difference between Unix & Linux? I want to learn Linux ownself without anybody's help, so what should i do now? Which web site or things will help me to learn Linux, plz let me know. For ISP which part of the Linux is important?
buts101
Full Member level 3
Unix/Linux
Hello there..
IF you want to learn by yourself...download some books related to redhat linux..u can get those pdf file in net...or redhat site...
And ISP use redhat these days...configuring web server,dns,dhcp,mail server and system administration are mainly used there.
Best Regards,
Buts101
tripathi
Unix/Linux
hello
unix can not have graphical mode but that is in linux
for lerning linux you can start from commond set. after that you go for internel and programming with linux.
davorin
Advanced Member level 3
Switzerland
Re: Unix/Linux
tripathi said:
hello
Please don't write rubbish....
Neither UNIX/Linux have something to do with graphics....it's the X window system available for all major flavours which does it...and there is no "grahical mode" at all (o;
drabos
Full Member level 6
Unix/Linux
UNIX has graphics mode as well.
Maybe the main difference that linux is free and the source is free, as well.
sajeev
Kerala-India
amihomo
Full Member level 5
PERSIAN Gulf
Unix/Linux
Hi
Linux was designd to be like UNIX, linux command produce the same output as the UNIX commands , but the internal implementation of them may differ.
The difference between linux & unix is that linux is free and open source but UNIX is commercial.
wangrunlai
Junior Member level 2
Re: Unix/Linux
amihomo said:
Hi
Yes, the hardware platform is special for unix and the linux is designed for PC which is popular used, also linux is free. The different is little between the Unix and linux, if u want to learning the Unix/linux, I think the book: UNIX: THE TEXTBOOK (author:Syed Mansoor Sarwar ... ) is helpful for u.
Phantom
Junior Member level 3
Unix/Linux
UNIX is commercial operation system, that was developed in early 1970th. UNIX is basis for modern commercial OSs like Solaris, HP UX, IBM UNIX ..
Linux is free OS that was developed using UNIX principle.
III
Full Member level 5
Macedonia
Unix/Linux
well once Unix was offered for free to universities but no longer and it's property software.
Linux was build from scratch by Linus Torvalds and friends, it has an open kernel and it's open source software.
About the user interface it's similar and different if U wan't to try a property unix get Sun Microsystems Solaris 10 for x86. It's not as good as most Linuxes and the license doesn't allow it's use on multi-processor systems! So I don't know what this means about dual core processors?
