May 6, 2006 #1 B Blilix Member level 1 Joined Feb 28, 2006 Messages 40 Helped 2 Reputation 4 Reaction score 0 Trophy points 1,286 Activity points 1,682 I have a cadence CD files which have this detail: ISR 2004202060002 I try to install this into SUSE 10 but when installing it asked me about lnx86 P/N 356-70352-303 CD-ROM Does this mean my cadence is not for linux or not? How can I solve this prolem? Could anyone tell me where I can get ic5141?
May 7, 2006 #2 eng_Semi Full Member level 6 Joined May 3, 2005 Messages 325 Helped 37 Reputation 74 Reaction score 6 Trophy points 1,298 Location Egypt Activity points 4,111 Any cadence software have a base, update, and hotfix releases. The update is called USR and the hotfix is called ISR. Actually u can't install neither the update nor the hotfix unless u have the base release CDs. For the name "ISR 2004202060002", it means that this is a hotfix which was released on 20/02/2006.
May 7, 2006 #3 B Blilix Member level 1 Joined Feb 28, 2006 Messages 40 Helped 2 Reputation 4 Reaction score 0 Trophy points 1,286 Activity points 1,682 So if I only have the ic5141 ISR cds, I can not set up ic5141 on my linux, right? If yes, could you tell me where I can get the base cds? thanks
May 7, 2006 #4 eng_Semi Full Member level 6 Joined May 3, 2005 Messages 325 Helped 37 Reputation 74 Reaction score 6 Trophy points 1,298 Location Egypt Activity points 4,111 I think that u will need the base CDs. U can get them from sourcelink.cadence.com, iff u have an account there. Else try to search the sharing programms
May 8, 2006 #5 B Blilix Member level 1 Joined Feb 28, 2006 Messages 40 Helped 2 Reputation 4 Reaction score 0 Trophy points 1,286 Activity points 1,682 Thanks eng_semi, where is the sharing program that I can get the base CDs?
