What is the difference between NPN and PNP bipolar transistor?
chuan556
Hi all,
May i know what is different between NPN and PNP bipolar transistor?
npn pnp difference
A Bipolar Transistor essentially consists of a pair of PN Junction Diodes that are joined back-to-back. This forms a sort of a sandwich where one kind of semiconductor is placed in between two others. There are therefore two kinds of Bipolar sandwich, the NPN and PNP varieties.
For more information see **broken link removed**
    chuan556
pnp npn difference
chuan556 said:
Hi all,
one difference is the material used.
npn and pnp difference
If you're interested I recommend you Sedra & Smith
difference npn pnp
NPN have two N type material and single P-type sandwitch between the two N-type. Reverse is the Case in PNP.
npn vs. pnp
the difference is on the basis of doping.
in NPN the n-type collector is heavily doped while p-type base is lightly doped.
in PNP the p-type collector is heavily doped and n-type base is lightly doped.
pnp and npn difference
chuan556 said:
Hi all,
ref malvino book
npn vs pnp transistor
you can also refer to "electronic devices and circuit theory" by boylested and nashelsky.
difference npn and pnp
The arrow head shows the conventional current flow direction.
pnp vs npn transistors
NPN transistors are supplied by +Vcc at the collector while PNP supplied -Vcc at the collector.
differences npn & pnp
you shoud concern with sedra & smith
npn pnp transistorer
´npn vs pnp
verry educational, thanks.
differences between npn and pnp transisitor
1. in NPN we have currents from Base to Emitter and Collector to Emitter but in PNP is opposite
2. NPN needs positive dc power supply connected to collector but PNP needs Negative one connected to Emitter
3. in NPN major carriers are electrons but in PNP is holes, so NPN is more rapid!!
difference of pnp to npn
npn
n is emmiter ,p is base,n is collector
pnp p is emitter ,n is base and p is collector.
NPN we have currents from Base to Emitter and Collector to Emitter.
npn instead pnp
I think its just a matter of our required application configuration just like motor if we want to rotate motor on both side we have to used both of this configuration (i-e one for clockwise and second for counter clockwise)
npn pnp different
I agree with all above members and i would like to add one more point,i.e.
In NPN , the majority charge carriers both inside the device and outside the device ( in wires connected to terminals) are electronics .
But, for PNP the majority carriers inside the device are holes and outside device are electrons.
you can refer this topic in the text on "PRINCIPLES OF ELECTRONICS"---V.K.Mehta
vissu[/youtube]
difference pnp npn
CARRIERS- IN npn CURRENT CONDUCTION IS B'COZ OF ELECTRON AND IN CASE OF PNP IT IS HOLES.
current flow directions in pnp & npn transistors
I will recommend a book "Electronics Principle by Albert Paul Malvino". A very good book for the bigginers, more practical approach.
