what is the difference between diplexer and duplxer?
cuizw
Newbie level 5
difference between duplexer and diplexer
Can anyone talk about the difference between diplexer and duplxer?
thank you!
difference between diplexer and duplexer
see and
and then use the search of the forum and perhaps you will find immediately the answers at your questions.
Regard
diplexer duplexer difference
Diplexer: can handle two diferent frequencies, just when
you use it to couple a single antenna to two or more transmitters
of different frequencies.
Act more like a combiner of different frequencies.
when receiving the diplexer separates the two frequencies
just like having two filters in parallel
Ex: cable and antenna combiner/splitter
Duplexer: can handle one single frequency, just when
used to couple a receiver and a transmitter of the same
frequency to a single antenna.
Act more like a circulator
In transmission the signal does not goes to the receiving path
just to the antenna. In receiving the signal does not go to the
transmiting path.
Example: Radar, same frequency but needs separation of
receiving path and transmiting path while using the same antenna.
So:
Diplexer = Combiner; two frequencies
Duplexer = Circulator; single frequency
some people call a duplexer a diplexer when use a "split". This is
not a duplexer. Esentially this is a diplexer with smal separation in
transmit and receive frequencies, they called this separation the "split"
what is diplexer
Actually a duplexer can be two different frequencies too. In this case, one antenna is used for both transmit and receive at the same time. For example, you have a duplexer in your cell phone. In the case of radar, typically, the reciever is turned off during the transmit pulse.
duplexer diplexer difference
This might be helpful.
