What is the data transfer rate of 8051 microcontroller?
8051 transfer rate
Arcoding to me . That is speed of transferring data which 8051 can do.Such as through UART of 8051 you can choose the "rate of transferring data" (baud rate)
9600 , 4800,2400...etc by control the overflowing of Timer1.
Re: 8051 transfer rate
Over the serial port maximum speed is 115200 Kbit/s, but with parallel implementation over the port pins, for example using epp/ecp with uC/PC comunication, speed can be higer than 1Mbyte/s.
8051 transfer rate
data transfer rate of what ??? in controller ram or through serial port ?
8051 transfer rate
8 bits per byte... :p
(GIGO)
JW
8051 transfer rate
it is actully depend on youe crystal
