Generally wrong, although I don't know what book you read.In various books it is given that the cutoff frequency should be fc=1/(pi*sqrt(Ltl(Ctl+C/l)))
What value do you set for reference impedance of ports ?but I don't see the same when I simulated.
50 ohm in both portsWhat value do you set for reference impedance of ports ?
In various books it is given that the cutoff frequency should be fc=1/(pi*sqrt(Ltl(Ctl+C/l))) but I don't see the same when I simulated. Thanks in advance.
So large mismatch at port, although I don't know what you set for "mtline".50 ohm in both ports
I used an RLGC file and the Z0 for line is more than 50 ohmIf mtline is setup as an ideal 50 ohm transmission line,
What quantity do you see in simulation ?I used an RLGC file and the Z0 for line is more than 50 ohm
No.I see cutoff Frequency of 119.43 GHz in simulation
No.
What quantity do you see to evaluate cutoff Frequency in your EDA Tool Play ?
You must not use S-parameter, since you can not understand RF and very basic things at all.I check S21.
What happens if the Line is not 50 ohm. is the same equation applicable?If mtline is setup as an ideal 50 ohm transmission line, the answer is very simple and you should be able to derive it yourself. Just a first order low pass with tau = c*Z0/2.
Then when to use this formula fc=1/(pi*sqrt(Ltl(Ctl+C/l)))? which scenarios, line with infinite length ?Theres's no simple cutoff frequency formula applicable.
If the port impedances are 50 ohm (i.e, in matched condition) voltage gain is equal to power gain (S21). When the circuit is Linear, Pout(dBm)= S21(dB)+Pin(dBm). So it doesn't matter which one I am looking at, all should give same cut off frequency.You must not use S-parameter
