What is the component "SMN2" , "SMP2" an
DZC
Full Member level 3
Refer to the Calibre LVS report as follows:
Layout Source Component Type
Ports: 19 19
Nets: 653 657 *
Instances: 215 217 * MN (4 pins)
122 123 * MP (4 pins)
10 10 C (2 pins)
80 80 R (2 pins)
323 323 INV (2 pins)
96 96 NAND2 (3 pins)
15 15 NAND3 (4 pins)
41 41 NOR2 (3 pins)
62 62 SDW2 (3 pins)
72 72 SUP2 (3 pins)
5 4 * SMN2 (4 pins)
4 4 SMP2 (4 pins)
varma_cs012
Member level 5
Hyderabad
Re: What is the component "SMN2" , "SMP2&quot
Those are the instances info what ever you used in your layout.
you can check the instances by using search option. Thank You.
Varma.
DZC
Full Member level 3
But I just can't find such component type: (
banvetor
Junior Member level 1
Brazil
Did you ever find out what were these instances, in special SDW2?
I have two nmos in my layout, that calibre is grouping in this SDW2, and I think that this may be the cause of the LVS error...
