T
treez
An external contractor has designed a 120W offline flyback SMPS for 190-270VAC input. It uses the FSCQ1565RT controller.
This flyback has no way of shutting down should the mains go below 190VAC....it will just increase its input current as much as is necessary to feed the load.
The FSCQ1565RT has an in-built primary current limit of 8A.....but for 120W load from 190VAC input, the peak primary current is only some 5A.
What is the chances of the EU and UK mains ever going below 190VAC for long periods?
Is there any situation whereby the EU or UK mains could go down to eg, 100VAC for long periods?
