May 7, 2007 #1 C cyw1984 Member level 2 Joined Sep 6, 2005 Messages 45 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,286 Activity points 1,643 input A0 A1 B0 B1 Cin output Sum0 Sum1 Cout.... Thx a lot
May 7, 2007 #2 pakitos Advanced Member level 1 Joined Nov 14, 2005 Messages 457 Helped 77 Reputation 154 Reaction score 35 Trophy points 1,308 Activity points 3,639 You mean 2 bit full adder !!! well attached is a powerpoint p;ease check it if you need help be more precise: full adder input: A,B,C output S and Cout Cout= AB + CB + AC S = (A' B + A B') XOR C = (A XOR B) XOR C
May 7, 2007 #3 C cyw1984 Member level 2 Joined Sep 6, 2005 Messages 45 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,286 Activity points 1,643 pakitos said: You mean 2 bit full adder !!! well attached is a powerpoint p;ease check it if you need help be more precise: full adder input: A,B,C output S and Cout Cout= AB + CB + AC S = (A' B + A B') XOR C = (A XOR B) XOR C Click to expand... O...sorry How about 2- bit full adder?? I can nit find in the powerpoint attached file Because I found that the S0 S1 and carry is very complex I found S0 is similar to 1 bit full adder....I also is A0 XOR B0 XOR Cin but S1 is very complex Any one can help....thank
May 7, 2007 #4 P pouchito Full Member level 2 Joined May 29, 2006 Messages 126 Helped 22 Reputation 44 Reaction score 9 Trophy points 1,298 Activity points 1,835 THANKS PAKITOS, excellent post . usually when they say full adder, we add three numbers, each number of 1 bit. the ppt that pakitos posted is graphical and EXCELLENT + contains correct and easy equations. cyw1984 you mean that you know the S0 but you want us to post the S1, right ? and why u said : O...sorry ??
May 7, 2007 #5 C cyw1984 Member level 2 Joined Sep 6, 2005 Messages 45 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,286 Activity points 1,643 pouchito said: THANKS PAKITOS, excellent post . usually when they say full adder, we add three numbers, each number of 1 bit. the ppt that pakitos posted is graphical and EXCELLENT + contains correct and easy equations. cyw1984 you mean that you know the S0 but you want us to post the S1, right ? and why u said : O...sorry ?? Click to expand... you mean that you know the S0 but you want us to post the S1, right ? YES REIGHT.. please post S1 and Cout...of 2-bit full adder...Thanks
