What is the blue ray technology?
my_books
Full Member level 5
What is blue ray ?
Re: What is blue ray ?
hi dear,
A Blu-ray Disc (BD) is a next-generation OPTICAL DISK format meant for high-density storage of HIGH DEFINATIO VEDIO and data. The Blu-ray standard was jointly developed by a group of consumer electronics and PC companies called the BLUE RAY DISK ASSOCIATION(BDA), spearheaded by SONY. The name Blu-ray is derived from the blue-violet LASER it uses to read and write to the disc. A Blu-ray Disc can store substantially more data than a DVD, because of the shorter wavelength (405 nm) of the blue-violet laser (DVDs use a 650-nm-wavelength red laser and CDs an infrared 780 nm laser), which allows more information to be stored digitally in the same amount of space. In comparison to HD DVD, which also uses a blue laser, Blu-ray has more information capacity per layer (25 giga bytes instead of 15) but may initially be more expensive to produce
Some more information::::
The Latest Technology taking over now.
SONY'S DISK drive division is working hard to introduce Blu-Ray.
It merged with NEC in April and will try to take as much market as possible. But despite the fact that some Blu-Ray consumer recorders are out and about, there won't be any computer drives on the shelves before August.
While Sony can't say much about the pricing of such drives, it can say one thing: they will be expensive. Its Blu-ray drives will be able to read and write DVDs, CDs as well as Blu-Ray disks.
In fact the disks are already available and they should cost between Rs 500 and Rs 750 for a single-layer 25GB disk and much more for 50GB dual-layer platter.
Sony brands its upcoming drive the BRU 100 A and it comes in rather interesting black and white design. Here's a picture of a picture of it.
What is a Blu-ray Disc?
A current, single-sided, standard DVD can hold 4.7 GB (gigabytes ) of information. That's about the size of an average two-hour, standard-definition movie with a few extra features. But a high-definition movie, which has a much clearer image (see How Digital Television Works ), takes up about five times more bandwidth and therefore requires a disc with about five times more storage. As TV sets and movie studios make the move to high definition, consumers are going to need playback systems with a lot more storage capacity .
BD-ROM disc researcher
Blu-ray is the next-generation digital video disc. It can record, store and play back high-definition video and digital audio, as well as computer data. The advantage to Blu-ray is the sheer amount of information it can hold:
A single-layer Blu-ray disc, which is roughly the same size as a DVD, can hold up to 27 GB of data -- that's more than two hours of high-definition video or about 13 hours of standard video.
A double-layer Blu-ray disc can store up to 50 GB, enough to hold about 4.5 hours of high-definition video or more than 20 hours of standard video. And there are even plans in the works to develop a disc with twice that amount of storage.
Source: White Paper: Blu-ray Disc Format
Blu-ray discs not only have more storage capacity than traditional DVDs, but they also offer a new level of interactivity . Users will be able to connect to the Internet and instantly download subtitles and other interactive movie features.
Blu-ray Advantages
record high-definition television ( HDTV) without any quality loss
instantly skip to any spot on the disc
record one program while watching another on the disc
create playlists
edit or reorder programs recorded on the disc
automatically search for an empty space on the disc to avoid recording over a program
access the Web to download subtitles and other extra features
Discs store digitally encoded video and audio information in pits -- spiral grooves that run from the center of the disc to its edges. A laser reads the other side of these pits -- the bumps -- to play the movie or program that is stored on the DVD. The more data that is contained on a disc, the smaller and more closely packed the pits must be. The smaller the pits (and therefore the bumps), the more precise the reading laser must be.
Unlike current DVDs, which use a red laser to read and write data, Blu-ray uses a blue laser (which is where the format gets its name). A blue laser has a shorter wavelength (405 nanometers) than a red laser (650 nanometers). The smaller beam focuses more precisely, enabling it to read information recorded in pits that are only 0.15 microns ( �m) (1 micron = 10-6 meters) long -- this is more than twice as small as the pits on a DVD. Plus, Blu-ray has reduced the track pitch from 0.74 microns to 0.32 microns. The smaller pits, smaller beam and shorter track pitch together enable a single-layer Blu-ray disc to hold more than 25 GB of information -- about five times the amount of information that can be stored on a DVD.
Source: Blu-ray Disc Association
Each Blu-ray disc is about the same thickness (1.2 millimeters) as a DVD. But the two types of discs store data differently. In a DVD, the data is sandwiched between two polycarbonate layers, each 0.6-mm thick. Having a polycarbonate layer on top of the data can cause a problem called birefringence, in which the substrate layer refracts the laser light into two separate beams. If the beam is split too widely, the disc cannot be read. Also, if the DVD surface is not exactly flat, and is therefore not exactly perpendicular to the beam, it can lead to a problem known as disc tilt, in which the laser beam is distorted. All of these issues lead to a very involved manufacturing process.
The Blu-ray disc overcomes DVD-reading issues by placing the data on top of a 1.1-mm-thick polycarbonate layer . Having the data on top prevents birefringence and therefore prevents readability problems. And, with the recording layer sitting closer to the objective lens of the reading mechanism, the problem of disc tilt is virtually eliminated. Because the data is closer to the surface, a hard coating is placed on the outside of the disc to protect it from scratches and fingerprints.
The design of the Blu-ray discs saves on manufacturing costs. Traditional DVDs are built by injection molding the two 0.6-mm discs between which the recording layer is sandwiched. The process must be done very carefully to prevent birefringence.
1. The two discs are molded.
2. The recording layer is added to one of the discs.
3. The two discs are glued together.
Blu-ray discs only do the injection-molding process on a single 1.1-mm disc, which reduces cost. That savings balances out the cost of adding the protective layer, so the end price is no more than the price of a regular DVD.
Blu-ray has a higher data transfer rate -- 36 Mbps (megabits per second) -- than today's DVDs, which transfer at 10 Mbps. A Blu-ray disc can record 25 GB of material in just over an hour and a half
Blu-ray vs. Other New Disc Formats
Formats
Unlike DVDs and CDs , which started with read-only formats and only later added recordable and re-writable formats, Blu-ray is initially designed in several different formats:
BD-ROM (read-only) - for pre-recorded content
BD-R (recordable) - for PC data storage
BD-RW (rewritable) - for PC data storage
BD-RE (rewritable) - for HDTV recording
Will Blu-ray replace previous DVDs? Its manufacturers hope so. In the meantime, JVC has developed a Blu-ray/DVD combo disc with an approximate 33.5-GB capacity, allowing for the release of video in both formats on a single disc. But Blu-ray is not alone in the marketplace. A few other formats are competing for a share of the DVD market.
HD-DVD
The other big player is HD-DVD, also called AOD (Advanced Optical Disc), which was developed by electronics giants Toshiba and NEC. HD-DVD was actually in the works before regular DVD, but it didn't begin real development until 2003.
The advantage to HD-DVD is that it uses the same basic format as the traditional DVD and can therefore be manufactured with the same equipment , saving on costs. The disadvantage is that it can't match the storage capacity of Blu-ray. A rewritable, single-layer HD-DVD can hold 15 GB of data; a double-layer disc can hold 30 GB (that's compared to 27 GB and 50 GB for Blu-ray). The read-only versions hold slightly less data. Also, HD-DVD doesn't offer the interactive capabilities of Blu-ray, although it will probably be less expensive than its competitor. For more information on HD-DVD, check out How HD-DVD Works.
