What is the big difference between vista and the xp ??
A.Anand Srinivasan
Advanced Member level 5
India
vista problems
i find that many softwares that work fine with xp and previous versions of windows do not work well in vista... what is the big difference between vista and the other versions of windows...
laststep
Member level 3
Malaysia
vista problems
Correct me if im wrong...
The main different is the vista is run using the 64bit platform and window xp is in 32bit platform. The way there process the data is different, so the program that previously can run at the window xp are not compatible with the window vista.
Marsel777
vista problems
This easy and simply
bmateusz
Newbie level 3
Hungary
Re: vista problems
I think there is 32bit Vista too. I haven't, and don't want to try Vista, because there are still many compatibility problems. Try to upgrade your softwares, maybe new a version supports vista.
"Nothing works on Vista, even Windows"
A.Anand Srinivasan
India
vista problems
vista has 32 bit version too... the one i'm using is 32bit version only...
bmateusz
Newbie level 3
Hungary
Re: vista problems
If your old softwares are important for you, and they can't run under vista, install an xp too, and you can dual-boot. You can emulate xp too, with VMware Workstation, or Microsoft Virtual PC.
A.Anand Srinivasan
India
vista problems
oh that is cool... i'll try that..
now can anyone tell me the reason for my first question...
graciousparul
Full Member level 2
Re: vista problems
There are many difference between Vista and XP, apart from it appearance, But most of it related to how manages memory, process etc. but the difference which can affect to programmes is its security architecture. In XP if any process running as service can have right of Local system administrator, which means it can do anything. While in Vista it is not the case. They have one more level of security. Also, on vista it is compulsory to have signed drivers, otherwise it wont allow you to install it.
For specific reason let us know which proram is not working. There may be possibility that the program using some undocumented API, and it is no longer supported in Vista.
ehsanelahimirza
Full Member level 6
vista problems
if some software is doing problem then there is option "install using recommended settings" use this thing (and get almost 85% results)
i got problem with TV card driver only. all other softwares i got working somhow
A.Anand Srinivasan
India
vista problems
i'm struggling in getting video converters for vista.... i wanna reduce some video sizes for burning..
VSMVDD
Banned
scotland uk
Re: vista problems
the main problem with most software and vista
proteus vsm grid dots missing is an example in vista but fine in XP
is caused by ati and nvidea cards poor support for other than games software !!!
im using a workstation enabled bios / video card
and this is quite easy to do just a few lines to draw with a pencil
i fixed this more fully
by using an older driver 7.4 ati for instance
and for nvidea i used one released in 2006
and again tweaked the bios/card to the workstation type
so if a windows program poorly performs
its usualy this
i also found that adding the vista RC3 service pak 1 {540mb !!!!}
fixed other issues with sound and slow 3d and poor sata performance
when using circuit board projections in protel and proteus vsm and others
even though microsoft issue hot fixes {updates}
there service pak seems to contain other core kernal elements
that fix many issues with memory leekages
there is also a RC3 xp sp3 release {330mb}
RC3 is usualy the one that gets RTM {released to manufacturer}
so install these and fix your graphics cards drivers back in time a little
{try to not use the fully WDM types as the models are crap }
even the gamers are moaning and issuing there own rebuilt drivers
....:cry:
above all there is no reason for you to use vista
its too new and software vendors run slowly
so i also implement a second hdd { a 120gb laptop drive}
i can switch off all the noisy coffee grinders and have a quiet XP on it
pure delight and helps you think
and again with no issues of vista
:D
vista is a poor example of a reskined previous XP o/s bit like ME was
A.Anand Srinivasan
India
vista problems
you have referred something about memory leakage... can you please brief that....
coz my sys memory space fluctuates in GBs and i dont have a clue on what it is doing....
tomanderson
Member level 1
vista problems
re-build software under vista may work if you have source code
A.Anand Srinivasan
India
vista problems
what can someone with little programming knowledge do with the source code???????
also only open source programs can atleast be tried in ur approach
