What is the best C compiler for AVR?
maziar
Full Member level 4
Islamic republic of Iran
post compile optimizer
i try select best c compile for avr for :
1. optimization (Size & Speed) [most important]
2. Bug free
3. good library
4. popular
5. good IDE
which of c compiler avr is better ? can help in compare ?
Re: Best C compiler for AVR
Most compilers are nearly bug free. But very difficult to expect and ensure zero bugs? Only by using!
Also look here:
best regards
GCC C compiler have power full libs, no experience
I worked with im@gecraft but its IDE is not good,I can say it have no IDE!
I think I@R c c0mpiler is the best for @VR.But you can not find a compiler of @vr Like as KKKKKeeeeeiiiillllll for 8o51.
bye
I think that I@R C compiler is a good choice
I would choose IAR or CodeVision.
If your code is not big, use codevision. Otherwise use IAR.
My opinion is -->Codevision
My experience,
a program for AVR Tiny26
Imagecraft: code size 83%
IAR: 61%
See the difference?
Hi andyyau
Did you check with Imagecraft Professional or Standard Version?
The Professional version incorporates code optimization and claims about 15% code size reduction!
andyyau said:
My experience,
IAR: 61%
See the difference?
please more comment
i no undestand Iar better or imagecraft for optimization ?
maziar said:
andyyau said:
My experience,
IAR: 61%
See the difference?
please more comment
I guess he means that his program ueses 83% of the Flash mem when he compiles it with Imagecraft and 61% when compiled with IAR.
So IAR makes the most compact code of the two, at least in this case.
I don't know how CodeVision compares to these two compilers.
What ramesh is refering to is the version of im@gecraft. The pro version has a post compile optimizer, the standard version does not. If he compiled under the standard version, that might be the size discrepancy. At one point in time, I looked at the difference in the generation of the two different versions. It was just an easy way of generating more money.
As for my two cents, I have used GCC and Im@gecraft. I would pick Im@gecraft any day of the week. GCC has so many quirks. If the code is not written just right (and I am referring to how the compiler wants to see it, not C standard) all sorts of unexpected things happen.
robotman
