What is the best book for OP design?
tony_wu_ad
Member level 3
I am trying to study the OP.
But I don't know what the best book is for the novice like me?
Your suggestion would be appriciated.
Thanks in advance.
Analysis and Design of Analog Integrated Circuits (Fourth Edition) by GRAY, Hurst, Lewis. Meyer
op-amp circuit design (using op-amp) or op-amp design (making op-amp)? These two are different aspects.
i would suggest "Introducton to CMOS Op-amps and comparators" by ROubik Gregorian, this book is same class as Razavi's book
regards,
smart
I want the book for op-amp design:)
Thank you very much!
Added after 4 minutes:
regards,
smart
Smart, Can you attach the book of "Introducton to CMOS Op-amps and comparators" , I can not find it :(
Thank you.
allen's coms integrate ciucuit design
I think you should read the book writed by Razavi
If you want a quick access to it, read Razavi's book.
If you want to learn more details, read Allen and Gray's books. And try to find more materials in IEEE.
introduction to cmos op-amps and comparators
Added after 1 minutes:
h**p://
Visiti Ti.com,and look for "OP for everyone",the file is very perfect about OP!
This post may give you some clues:
hxxp://
Razavi's book "design of Analog CMOS Integrated Circuits" chapter 9&10;
allen's book "CMOS Analog Circuit Design"chapter 8&9
Can try out the following
''cmos analog circuit design'' allen and holberg
I'd like to recommend Allen's book, and the reason is you can find how to test(in simulation) the opamp's open-loop gain, ICMR, output swing and other parameters.
you can try also opamps by Barna. I think I have the file somewhere in pdf..or you can find it maybe on the site
Added after 10 minutes:
here is the link
Analysis and Design of Analog Integrated Circuits (Fourth Edition) Gray
For opamp simulation: Cmos analog circuit design, Allen
Step by step, just begin with some basic simple amplifiers.first read the book,and then you can do simulation with Hspice.
There are many books about op amp design, you can download it free.
Some opamp examples.
Op Amp.Applications.Handbook (2005)
Allen's book "CMOS analog circuit design"
