What is the application of the 'image and 'value attribute in VHDL?
matrixofdynamism
Advanced Member level 2
The 'image attribute in VHDL returns a string for certain types. The 'value attribute is opposite to the 'image attribute. Correct?
(1) The 'image attribute can be used to print value of certain types to transcript using report command. What else would it be used for?
(2) Why does 'image attribute not exist for std_logic_vector? That makes no sense at all.
(3) When would one need to use the 'value attribute?
FvM
Super Moderator
Staff member
Bochum, Germany
Why not read the VHDL language reference? It tells that IMAGE and VALUE attribute can be applied to scalar types and its subtypes. Std_logic_vector isn't a scalar, it's a bit array.
K-J
For constructing the name of a file to read or write from the testbench
But there are packages that do exactly that
After you've read in something from a text file that you would like to use in your testbench.
Using image in report statements is probably the most common usage. Although not entirely the case, whether you use image/value a lot or a little seems to depend on how much you like to interact with external text files in your testbench. So, in the end, it's one of those 'handy some of the times' things more than something that you use a ton.
Kevin Jennings
matrixofdynamism
What package coverts std_logic_vector to hex and which package can return a string representing hexadecimal equivalent for a std_logic_vector?
TrickyDicky
Advanced Member level 5
In VHDL 2008, the std_logic_1164 package.
Pre 2008, the std_logic_textio package (its non standard, but included in all simulators).
