what is that warning mean while loading simulation?
JKR1
Junior Member level 3
hi
can anybody help me what does mean that warning while loading simulation?
** Warning: (vsim-3473) Component instance "uut : main1" is not bound.
Is this warning could affect the simulation ??
thanks
It means that it didn't find the component main1. Make sure that the component main1 is compiled and that you instantiate correctly that component in your testbench.
Your simulation won't work because there component main1 is "empty".
Reactions: JKR1
    JKR1
usually happens if there is some mismatched ports in the actual entity declaration and the component declaration. Basically it means the component instance wasn't attached to the rest of the design so you'll definitely have a simulation that doesn't run correctly.
Reactions: JKR1
    JKR1
