What is SETUP violation and HOLD violation?
bala9383
Member level 1
what is SETUP violation and HOLD violation??
differnce bet' positive and negative skew.
Re: ASIC-Synthesis
A hold time violation, when a signal arrives too early, and advances one clock cycle before it should. Hold violations are not dependent on frequqncy. These are mainly because of clock reaching late at capturing flop.
A setup time violation, when a signal arrives too late, and misses the time when it should advance. Setup time is related to frequency of operation. When path is violating setup that means it can not work on that particular frequency.
Positive skew is when the clock reaches the receiving register later than it reaches the register sending data to the receiving register. This can help in meeting setup timing but it can cause hold violations.
Negative skew is the opposite, when the receiving register gets the clock earlier than the sending register. This can cause setup violations.
