What is RFC for in this mixer?
tony_lth
Beijing
Hi, Gurus,
I met this mixer circuit, as the following picture.
I have several questions:
1. What is the RFC for?
2. If for matching the input of diodes, why it is in the root of the pin? And the diodes input impedance should be varied by the freq and input LO power level, right?
Best,
Tony Liu
    tony_lth
In the attachment report, it showed the conversion loss when IF=1Hz, 100Hz. How can they do so?
I guess they tested in Radar, but how to calibrate the test system?
Best,
Tony Liu
    tony_lth
"using two signal generators", that's what I am curious.
It sounds impossible to find IF=1Hz for two signal generators.
So they should test in radar.
I don't know where you see 1Hz. Minimum shift frequency in Fig.10 is 10Hz.
Anyway, to test with accuracy in a radar, and to don't do this in a field, they may use a Doppler (velocity) emulator, which are pretty expensive devices.
But two signal generators (one for RF and one for LO) connected both to the same reference (10MHz let's say) may do the job.
    tony_lth
LaTeX Commands Quick-Menu:
