what is phase ,frequency spectrum ,gain ,unity gain?
m_Hadad
Newbie level 5
hi evreyone,
i'm a begginer in DSP and i'm trying to know some terminilogies related to this science.i'm reading a book called DSP for scintists and engineers.i have some background in electronics and i'm a programmer.so please bare with me.
there is some phrases in this book that i couldn't understand like the following:
when random noise signals combine in an electronic circuit, the resultant noise
is equal to the combined power of the individual signals, not their combined
amplitude.
in chapter 2
i would be gratefull if someone could help me in learning dsp.
regards.
zeeshanzia84
Full Member level 3
Pakistan / Germany
PHASE: Time shift between two signals of same frequency for e.g.
sine and cosine have a phase difference of 90 degrees. i.e. if you advance the time scale by 90 degrees the sine wave becomes a cosine.
sin (90 + θ) = cos θ
FREQUENCY SPECTRUM : If you know about FOURIER TRANSFORM, you should know that all signals can be broken up into their constituent sinusoidal components. A graph that shows the amplitude of these frequency components is called Frequency Spectrum.
GAIN: The gain of an amplifier is the factor by which it multiplies the input signal and gives you an greater amplitude o/p signal.
Vout = G x Vin
UNIT GAIN: If G=1, it is called unit gain.
    m_Hadad
