What is MIM capacitor and why do we need them?
VLSI_Learner
Member level 2
Member level 2
What is MIM capacitor?
Why it is needed in your layout, when the basic idea is to remove parasitic capacitor as much as possible?
When it is needed?
MIM or metal insulator metal capacitor, sometimes referred as conductor-insulator-conductor, is one type of available capacitor types in a typical CMOS technology. There are many reasons to use a capacitor in your circuit (SC, pole splitting, etc ).
Hope this helps.
BR Jerry
MIM capacitors basically a parasitic capacitor between the metal layers(MIM -->Metal insulator Metal). Generally CTM mask layer is used for insulation. U will get an accurate capacitance value in this but it takes lot of area.
This is needed parasitic to increase the cap.
Can you please tell me MIM's which capacitor is attached to what in layout, when we place MIM cap in our layout?
The main virtues of MIM caps are low voltage coefficient
and low / low variability series resistance. Both of these
are poor on MOS capacitors, for example a high-VT NMOS
capacitor has negligible C and near infinite ESR when Vgs=0
(channel is "off", which is your connection to the bottom
plate).
MIM tends to have lower C density (consume more area).
A depletion mode MOS cap probably beats it, there. A
composite MIM-over-MOS can be a good high density,
decent-net-Q decoupling structure if that stack is DRC-
legal (this varies, underlying topography can affect MIM
matching and reliability / breakdown).
