What is inside of gates and buffers?
osmansafa
Newbie level 6
Newbie level 6
hi i am taking both logic and circuit analysis but i wonder what is inside an AND gate (also all other gates), transmission gates ,tri-state buffer and also dependent voltage or current sources can you explain or suggest some reading but note i havent taken any electronics yet thanks in adance
inside of components
Hi
You can find the data sheets on the net, for example https://www-ee.eng.hawaii.edu/~tep/EE260/TTL/Datasheets/7400.pdf,
in order to understand in detail the internal circuits in the logig gates you need to study advanced circuit analysis and microelectronics. If you ask my opinion, there is no point in going further studying the inside of logic gates if you are not going to work in microelectronic or integrated circuits design, if you want to work in companies like Intel, Texas instruments or others which make circuits, then you go and study more about it.
if this helps you, please click on "helped me" for statistics
Sal
    osmansafa
Re: inside of components
Transistors :D
    osmansafa
