What is IEEE 802.11a,b and e?
Rayengine
Full Member level 5
Hong Kong
As we know that the WLAN specification is IEEE 802.11, but can some tell me that the difference between them
(1) IEEE 802.11a
(2) IEEE 802.11b
(3) IEEE 802.11e
Rgs
Rayengine
flatulent
Advanced Member level 5
Middle Earth
some guesses
a is the 5 GHZ band direct spread modulation. b is the 2.4 GHz band direct spread modulation. The other may be frequency hopping or IR.
flatulent
Middle Earth
correction to last message
E is probably OFDM in the 5 GHz band set aside for data transmission.
Darkseed
Member level 2
Quoting IEEE sources:
"The purpose of Task Group E is to: Enhance the current 802.11 MAC to expand support for applications with Quality of Service requirements, and in the capabilities and efficiency of the protocol."
eda_wiz
Advanced Member level 2
hi there ,
in a and b ieee specifies the physical layer , while in e the changes are in mac layer . and can use a physical layer with a or b spec..
a gives more importance to data rate --54mbps
b has only 11mbps , popular soho choice.
e is used for QoS needed networks with applications like real time multimedia streaming and all.
