[SOLVED] what is ideal throughput for AXI bus?
u24c02
Advanced Member level 1
Hi i have question.
I using 200Mhz clock to axi 32bit bus.
But i'm not sure about ideal bus throughput.
Does anyone knows what have throughput in ideal axi bus kb/s?
If you can would you please let me know what how to calculate bus bandwidth and throughput?
For 32 bit bus running on 200 MHz clock, Bandwidth=200*32=6400 megabits bits per second or 6.4 Gbps.Throughput= actual data rate obtained during normal operation. throughput <= bandwidth
