what is header files in embedded c programming
bbgil
Full Member level 2
Full Member level 2
hi. i'm learning embedded c, and i came across this header files in one of the example project of MikroC, Display1_utils.h . i try not to use it but i didn't work. What is the purpose header files? i check the header and it only contain a single line. Any explanation here is appreciated. thnx in advance.
hi,
a little explenation:
https://en.wikipedia.org/wiki/Header_file
in short, ehader file is very useful to make modular development, where the applicaiton is divided in to many source codes modules
regards,
    bbgil
It is easier to manage code if you split a program into files. It also promotes reusable code. For instance, you can write a file that just deals with PWM functions, one that just deals with A/D functions, one with just timer functions etc. The header file exposes only the function prototypes that are called from the main thread, so the linker may find them.
Declaring a function static in a file limits it's scope to that file.
Taking it further, the code in the file can be optimised and fully debugged, you can then compile it to a library. In future projects, you can include the header file and the linker will only link in the functions you call. So you get rapid application development with known good working code.
    bbgil
