what is ground bounce and how to elimate it?
linuxluo
Full Member level 6
Full Member level 6
ground bounce means the 0V power net is not 0V in your chip/board, some noise on you power net.
using de-coupling cell in your chip
sunjimmy
Full Member level 2
Full Member level 2
Ground bounce is due to rapid current sink/source thru bonding wire between ground pad and package pin. dV= L(dI/dt)
SO the methods to mitigate this ground bouncing effect are:
(1) lower the inductance(L):
for example; double/triple bonding for groung pin. or using flip-chip packaging, ...,etc.
(2) lower the current spike(dI/dt):
for example; using slew-rate control output buffer, decoupling cap in internal power-gnd net, well controlled slew-rate of internal signal with adequate buffer size, ..., etc.
Hope it helps :)
muralicrl
Full Member level 5
Full Member level 5
Bangalore
Kindly see the attachment.
Regards,
N.Muralidhara
CRL-BEL
ls000rhb
Full Member level 3
Full Member level 3
power network layout maybe import , power pad numbers also needs consideration.
vsmGuy
Advanced Member level 2
VddVss
Experience from the trenches say, the easiest way out is :
Pulling appropriate caps near the ground pins of each IC and enough provision for copper pour dedicated to ground.
vamsi_addagada
Full Member level 2
Full Member level 2
bangalore
hi murali
i didnt got any attachment from u r side. plz send me attachment
vamsi
gurpreet.singh
Junior Member level 2
Ground bounce is a phenomenon associated with transistor switching where the gate voltage can appear to be less than the local ground potential, causing the unstable operation of a logic gate.
