Glitch - Wikipedia, the free encyclopedia
"An electronics glitch is an undesired transition that occurs before the signal settles to its intended value. In other words, glitch is an electrical pulse of short duration that is usually the result of a fault or design error, particularly in a digital circuit. For example, many electronic components such as flip-flops are triggered by a pulse that must not be shorter than a specified minimum duration, otherwise the component may malfunction. A pulse shorter than the specified minimum is called a glitch. A related concept is the runt pulse, a pulse whose amplitude is smaller than the minimum level specified for correct operation, and a spike, a short pulse similar to a glitch but often caused by ringing or crosstalk. A glitch can occur in the presence of race condition in a poorly designed digital logic circuit."
Glitches in digital circuit can cause increased power consumption due to unnecessary switching.
