What is Flash Memory Address available for pic16f877a?
ryusgnal
Malaysia
What is Flash Memory Address available for pic16f877a? So I can use it to store 256 byte data into it.
thank you....
blueroomelectronics
Advanced Member level 5
Toronto, Canada
Re: Flash Memory Address
thank you....
Yes, you can use either EEPROM or Flash for storing data. Using Flash is a little trickier in the 16F87x series and easy in the 18F.
ryusgnal
Malaysia
blueroomelectronics said:
thank you....
what is the addresses available for EEPROM and Flash memory in pic16f877a?
ryusgnal
Malaysia
It's in the datasheet. 368bytes EEPROM, Flash is the entire 8K range.
If I want to write the program, what address I should use to store the 256 bytes data.
example: Flash_Write(0X****, dataWr);
what should I put at ****?
drbizzarow
Advanced Member level 1
u dont need to write your program if you ar programming in PCW or other C compiler .... they got builtin fuction to do this ....write_eeprom(address,data); you can find help in your compiler to undestend ....... other usefull thing is u dont need to bother their addresse if you wanna write at first location of their flash eeprom then address will be 0 ie: write_eeprom(0, 0xaa);
ryusgnal
Malaysia
Is it o.k to put data at first location? I afraid if they put special register there. is it enough to store 256byte data?
mongoose
Newbie level 6
Yes,you can,I use mine to store varibles on.
Here is the code to store varibles (in pic C).
#define LAST_VOLUME 10
A = read_EEPROM (LAST_VOLUME);
A;
write_eeprom(LAST_VOLUME,A);
Mongoose
Bj Erasmus
laktronics
Banned
As a standard, PIC ICs use the starting address of EEPROM at 0X2100 and with 256 bytes, it goes up to 0X21FF. The Flash memory of 8k resides in the address map 0X0000 to 0X1FFF . If the C allows to write to these locations as an array, you should do that instead of writing at absolute addresses since the code also resides in this area.
Regards,
Laktronics
