W_Heisenberg
Full Member level 4
For a computer, I think they should have these things maybe on mother board. But how does these things work?
Anyone points this out for me?
Kernel is a part of an operating system that acts as an intermediary between applications and the hardware of the computer. e.g CPU and memory.
Firmware is software that typically exists on a microchip device. Your PC's BIOS is one example. The simple (Basic Input Output System, BIOS) program that runs every time you turn on your PC scans/communicates with your CPU, RAM, video card, hard drives, floppy drives, USB controller, etc. Since the program is stored (and run) on a chip, it's called "firm"ware, whereas "soft"ware is loaded from a flexible source (a hard drive) and typically run on a general purpose processor (your computer's CPU).
Firmware - Wikipedia, the free encyclopedia
A kernel is a (mid-level) piece of software that interfaces between applications and the PC's hardware. It's not as low-level as firmware (which often runs ON the hardware, itself); nor is it a high-level program like a user program (word processor, spreadsheet app, browser, etc). Unlike firmware, the kernel is software, as it gets loaded into memory when a PC boots from the hard drive (it's one of the first things to get loaded and executed).
Kernel (computing) - Wikipedia, the free encyclopedia
kernel is defined as the link between application and hardware components,
but is kernel circuit? or soft-codes?
we can update firmware, yet can we update kernel as well?
The difference between software and firmware is blurry, as a kernel (software) can be part of a firmware.
Wikipedia says that "...There are no strict boundaries between firmware and software, as both are quite loose descriptive terms..."
Kernel has to be thinked as the core; the main module that allows higher level software to run.
