What is Error Amplifer used for ?
Jeslyn_83
What is an error amplifier use for?
mister_rf
Advanced Member level 5
Romania
Re: Error Amplifer
An error amplifier is most commonly encountered in feedback unidirectional voltage control circuits where the sampled output voltage of the circuit under control is fed back and compared to a stable reference voltage. Any difference between the two generates a compensating error voltage which tends to move the output voltage towards the design specification.
Jeslyn_83
Re: Error Amplifer
I have construct an error amplifier using MOSFET. By injecting the input V-=5V and V+= 6.0893V and simulate through PSpice. The output i got is 1.3922V.
Is it simply by substracting the V+ and V- to get the output. If so, why the voltage is abit higher compare to the calculation?
Audioguru
Toronto area of Canada
Error Amplifer
Your Mosfet doesn't have much voltage gain. Usually an opamp with an internal voltage gain of 200,000 is used as an error amplifier.
Jeslyn_83
Re: Error Amplifer
Can you tell me how to increase the voltage gain?
and what should the output be?
Audioguru
Error Amplifer
You forgot to attach your circuit so how am I supposed to see what it is???
Is it a voltage regulator?
What are you using as its accurate reference voltage?
Jeslyn_83
Re: Error Amplifer
ops... I am designing a DC-DC down converter. Here is my attach file.
Thanks. I have just upload the circuit.
Audioguru
Error Amplifer
I got an error that says your file does not exist anymore.
Added after 3 hours 59 minutes:
I can see your schematic now.
It is the size of my entire neighbourhood so I see only one small part then I must scroll th see more.
It looks like you are making your own Cmos opamps.
