what is double bondind in power pads
vsrpkumar
Member level 4
need for double bonding power pads
what is double bonding in power pads in asic.why this concept is needed.
Thanking you
kumar
stormwolf
I remember use two bond pads connect outside power. Use two bond pads it can reduce resistance.
It can reduce IR drop at power net.
    bgangur
vsrpkumar
Member level 4
Why
is this required exactly.I needed material.Thanking you
kumar
funster
Full Member level 4
double bonding is to increase current carrying ability of power pad
by using two power pad.
best regards
Thanking you
kumar
    bgangur
