Path based STA is broadly used by current STA sign-off tool (Primetime, TimeCraft). Timing constraints will be checked at endpoint of the timing path.
the AT of endpoint should less than RT.
BLock Based STA:
timing constraints will be checked at each node of the timing path.
each node own its AT and RT. If its AT less than RT, timing is ok.
