what is cross correlation?
ann_ren
Junior Member level 1
can some one pls tel me what is cross correlation and auto correlation of codes??
why are these two properties so important in cdma of NoC..??
Aya2002
Iraq
it is very important to you to know at first what is the physical meaning of correlation. It is a comparison of two signals to see the degree of similarity between them,
in CDMA, at the receiver, it will compare the sent code with the saved code at the receiver, if it is similar then, this means it will decode it to produce the original transmitted signal.
regards
