what is conventional PCB trace thickness?
jayleung
Member level 5
pcb trace thickness
Hi, everyone. I have a question about the conventional PCB trace thickness. What is the relationship between the thickness and copper weight, since I saw many PCB manufacture give the specification of copper weight. Thanks.
Tohu
Full Member level 1
pcb copper thickness
35 um is the standard, what is the connection i don't know, may be this is the weight for 1 sq.in or 10 sq.in ..... but 0.035 mm is the standard.
Reactions: nepdeep
    jayleung
    nepdeep
House_Cat
USA
trace thickness
The thickness of copper clad on a circuit board is usually given in ounces (oz). It is the weight of copper on one square foot of board. One ounce copper is 1.378mils (~35um) thick.
Normal PCB copper thicknesses are 1/4oz, 1/2oz, 1oz, and 2oz. Other thicknesses are possible, depending on the capabilities of the fabricator that makes your board. However, copper that is too thick creates lamination problems.
A typical board would use 1/2oz (.7mil or 18um) copper on inner layers, and 1oz (1.4mil or 35um) copper on planes and outside layers. If the board is thin and high density, thinner copper clad would be used to keep the weight and finished board thickness as small as possible.
angelote
Spain
copper trace thickness
For example, check "FAST LINKS TO TECHNICAL SUPPORT" on this PCB manufacturer:
h**p://www.lab-circuits.com/welcom.htm
