What is case analysis and how to disable the timing arc in Design Compiler?
suribabut
Newbie level 2
Newbie level 2
what is case analysis ?.........
How can I disable the timing arc's in Design Compiler ..........
Re: case analysis
you can using following commonds,
set_disable_timing,
set_case_analysis,
set_group
set_false_path
David
Added after 1 minutes:
detailed infor, refer to DC userguide or PrimeTime userguide.
Re: case analysis
for example, you have a clock mux , one input is normal clock , another is test clock, the two clocks work in diff period. the slow test clock may have a hold violation , the normal clock may have a setup violation. you can use set_case_analysis to analysis the timing of the design.
