What is Build In Testing (BIT) and how to implement it?
nlksg
Junior Member level 3
Singapore
Any one can explain me what is Build in testing BIT? Is it something like POST in our PC motherboard BIOS? How do we usually impliment it in our circuit design?
nlksg
Re: Build In Testing (BIT)
Hi
BIT is software for testing hardware element on your board:
For instance - let assume you have an EEPROM memory on board and you would like to test it
You will write a routine (best to use the driver interface already written for it) who handle writing to the EEPROM, reading back the written data and comparing the written data and read back data
If the data is the same - then you can assume that the device is operating
All the best
Bobi
    nlksg
nlksg
you can do google if you want a fast answer.
