What is Boiling Test in the IC Fabrication??
acey80
Newbie level 6
What is the Boiling Test for? and How is it conducted?? I tried to find it in the Internet but NONE! Thanks!
Any more details ?
Typical IC qualification tests include:
Hot Ambient Stress Testing : just temperature and voltage stress tests.
High temp operational Life : same as above but with IC constantly exercised over 1000 hours.
Autoclave : Hot humid testing for packaging.
Thermal cycling : -40 deg C to 125 deg C ramp up down to test packaging
:?: It's about the IC Test after fabrication.... Anyway, thanks!!
Not sure about this boiling test, but I suspect maybe you mix it with "burn in" test.
Do you means oil dipping with 200c, then perform
test?
