what is back drilling and why is it preffered?
v_kumar
Full Member level 5
India
what is back drilling and why is it preffered.
thanks
majnoon
Full Member level 5
Re: Back drilling
It is a process to remove the unused section of plated through holes.
This will ensure signal stubs are minimized; Stubs are the source of impedance discontinuities and signal reflections which become more critical as data rates increase. It is preferred method in HS designs.
Allegro handles back drilling processes.
Regards,
M
v_kumar
Full Member level 5
India
Back drilling
Why should we go for back drilling and not for blind and burried vias because the end result is the same minimizing stub.
Thanks
vengat
Newbie level 5
Re: Back drilling
Thanks
Hi V_kumar,
Main Purpose of Back drilling is Signal Reflection and Reduce the Stub,
we can do back drilling or Blind or Burried Vias,
when we go for Blind or burried via,manufacturing cost will increase
thanks
Vengat T
Scottm
Member level 1
Scottish Borders
Re: Back drilling
Another reason for backdrilling instead of using blind and buried is if you are using it in a backplane, you most likely will not have many vias as you will be going from connector to connector so you would be backdrilling the connector pins which wouldn't be blind or buried.
cheers
Scott
v_kumar
Full Member level 5
India
Back drilling
If we backdrill the connector pins than how can we solder it from the other side since it is a PTH connector. can you upload any pic for this to make clear pitcher
What are the files to be sent to manufacturer to do the back drilling.
Scottm
Member level 1
Scottish Borders
Re: Back drilling
in the designs i was talking about we use press-fit connectors so no soldering required. The files we typically send are just modified drill files that give the coordinates of the holes to be back drilled they also include the a fab drawing with the depth of each drill required.
    v_kumar
