What is a SMPS inverter ?
shoeb.eee
Member level 1
I studied about Square wave inverter, PWM inverter, Sinusoidal PWM inverter, Modified Sinusoidal PWM inverter. From them Modified Sinusoidal PWM inverter is the best.
I know SMPS. It is a dc-dc converter power supply.
But What is SMPS inverter?
kabiru
Banned
Nigeria
Re: about SMPS inverter
Hi, the smps inverter is a DCtoAC inverter but DC-DC converter is used to convert 12dc to about 340vdc and this voltage is converted to 240AC 50HZ.therefore the inverter uses ferite core transformer.
shoeb.eee
Member level 1
about SMPS inverter
12v dc to 340v dc means boost converter. May I get help to make this?
kabiru
Banned
Nigeria
Hi shoeb.eee, i dont think is a
problem, all you need to do is to
build an oscilator using SG3525
OR 3524 with very high freq to
swich your ferrite core
transformer with your
mosfet,then rectified the out put
with highfrequency rectifiers with
your filtered output,using pwm
technics;note number of turns
ratio determine's your output
voltage.
rajudp
Advanced Member level 2
India
yes but more of the design using push pull converter for more efficiency than boost converter
kabiru
Banned
Nigeria
Yes most of the inverter using smps they are usualy push pull arrangement.
Spidyelectronics
Member level 2
INDIA
about SMPS inverter
Hi shoeb.eee,
You can check on TI website. there are some articals on SMPS.
shoeb.eee
Member level 1
about SMPS inverter
Thanks everybody!
I understood.
Designing the transformer will be a great challenge.
If I need 340W output Transformer's current ratting will be Ip=28.33A and Is=1A (Vp=12, Vs=340)
So, I need help regarding high frequency (100kHz-400kHz) Transformer
shoeb.eee
Member level 1
about SMPS inverter
Waiting for your response ...
shoeb.eee
Member level 1
about SMPS inverter
anybody please response
MAXPAYNE
Member level 5
BD
I have used 3525 for the DC-DC stage using push-pull. but what i got was not good. if u want to fix the voltage at 360 V dc(using feedback) whatever chnge in the load, then this PP topology creates lots of heat and often burning of FET though using snubber. So i think Boost topology should be used...........
Added after 4 minutes:
have u tried anything yet ?
sec
Canada,QC
boost converter and push-pull are bad idea, look for some forward converter. For 340W it's your best guest !! flyback converter are quite are to design due to the transformer spec but cold be good too. The forward converter is something between push-pull (easy to design) and flyback (low cost and good efficiency) boost converter is a bad idea because the duty-cycle is quite large 12V to 340V. I recommand to not go over 100
khz, you will have a bad time choosing a mosfet (28A @ 100kHz). DigiKey, mouser, Newark, etc sells good ETD core working at 65KHz.
the link:
https://schematic-diagram.blogspot.com/search/label/DC-DC INVERTER
shows a push-pull converter made out of a 3525. The push-pull topology is used in car power amplifier, the output voltage is low-to-med (not 340V)
the design on the link is poor and lack of protection(and compensation)
Tahmid
Advanced Member level 5
Silicon Valley, California, USA (from Dhaka, Bangl
about SMPS inverter
I think you should check this out:
http://sound.westhost.com/project89.htm
In my SMPS inverter, I used turns: primary 4-4 turns, secondary 110 turns.
After that use an SG3525 or SG3526 oscillating at 50Hz with a deadtime and feed this to a MOSFET bridge through a hi-lo side driver IR2110 or L6385/6/7/8. Filter the output with two inductors and a capacitor.
Hope this helps.
Tahmid.
MAXPAYNE
Member level 5
BD
the link:
what if u design the boost converter in two stage ???
Added after 7 minutes:
Hope this helps.
Tahmid.
have u used push-pull topology ? how do u regulate the 360 V dc ? r u frm uttara ? if so have a desire to meet u :)
Tahmid
about SMPS inverter
Hi Maxpayne,
I used push-pull topology with SG3525 and regulated the output with feedback (resistive divider). Then I used PIC12F675 to provide 50Hz pulse with 80% duty cycle to provide modified square wave output.
Later I changed the design and substituted with an ATmega88 which does everything.
Hope this helps.
Tahmid.
Yea, I'm from Uttara.
MAXPAYNE
Member level 5
BD
Tahmid said:
Hi Maxpayne,
Hope this helps.
Tahmid.
I have done the same thing previously using p-p . but when duty cycle was close to 70%, the mosfet got damaged....mmany a times....and the fet was heating tremendously....... but when i removed the fb (resistor divider) everything worked as desired. no extra heat. although output dc wasn't regulated....wht could be the reasn tahmid ?
in uttara which sector u r in ?
Tahmid
about SMPS inverter
This obviously seems to be a problem with the feedback loop. Maybe a miscalculation of resistor / capacitor value. Hard to tell without actually looking at the circuit.
I live in Sector 10.
Hope this helps.
Tahmid.
