Hello
Under Unix/Linux...
IPC:Semaphores
Semaphores are a programming construct designed by E. W. Dijkstra in the late 1960s. Dijkstra's model was the operation of railroads: consider a stretch of railroad in which there is a single track over which only one train at a time is allowed. Guarding this track is a semaphore. A train must wait before entering the single track until the semaphore is in a state that permits travel. When the train enters the track, the semaphore changes state to prevent other trains from entering the track. A train that is leaving this section of track must again change the state of the semaphore to allow another train to enter. In the computer version, a semaphore appears to be a simple integer. A process (or a thread) waits for permission to proceed by waiting for the integer to become 0. The signal if it proceeds signals that this by performing incrementing the integer by 1. When it is finished, the process changes the semaphore's value by subtracting one from it.
Semaphores let processes query or alter status information. They are often used to monitor and control the availability of system resources such as shared memory segments.
Semaphores can be operated on as individual units or as elements in a set. Because System V IPC semaphores can be in a large array, they are extremely heavy weight. Much lighter weight semaphores are available in the threads library (see man semaphore and also Chapter 30.3) and POSIX semaphores (see below briefly). Threads library semaphores must be used with mapped memory . A semaphore set consists of a control structure and an array of individual semaphores. A set of semaphores can contain up to 25 elements.
In a similar fashion to message queues, the semaphore set must be initialized using semget(); the semaphore creator can change its ownership or permissions using semctl(); and semaphore operations are performed via the semop() function.
semaphore.c: Illustration of simple semaphore passing
/* semaphore.c --- simple illustration of dijkstra's semaphore analogy
* We fork() a child process so that we have two processes running:
* Each process communicates via a semaphore.
* The respective process can only do its work (not much here)
* When it notices that the semaphore track is free when it returns to 0
* Each process must modify the semaphore accordingly
#include <stdio.h>
#include <sys/types.h>
#include <sys/ipc.h>
#include <sys/sem.h>
union semun {
int val;
struct semid_ds *buf;
ushort *array;
main()
{ int i,j;
int pid;
int semid; /* semid of semaphore set */
key_t key = 1234; /* key to pass to semget() */
int semflg = IPC_CREAT | 0666; /* semflg to pass to semget() */
int nsems = 1; /* nsems to pass to semget() */
int nsops; /* number of operations to do */
struct sembuf *sops = (struct sembuf *) malloc(2*sizeof(struct sembuf));
/* ptr to operations to perform */
/* set up semaphore */
(void) fprintf(stderr, "\nsemget: Setting up seamaphore: semget(%#lx, %\
%#o)\n",key, nsems, semflg);
if ((semid = semget(key, nsems, semflg)) == -1) {
perror("semget: semget failed");
exit(1);
} else
(void) fprintf(stderr, "semget: semget succeeded: semid =\
%d\n", semid);
/* get child process */
if ((pid = fork()) < 0) {
perror("fork");
exit(1);
if (pid == 0)
{ /* child */
i = 0;
while (i < 3) {/* allow for 3 semaphore sets */
nsops = 2;
/* wait for semaphore to reach zero */
sops[0].sem_num = 0; /* We only use one track */
sops[0].sem_op = 0; /* wait for semaphore flag to become zero */
sops[0].sem_flg = SEM_UNDO; /* take off semaphore asynchronous */
sops[1].sem_num = 0;
sops[1].sem_op = 1; /* increment semaphore -- take control of track */
sops[1].sem_flg = SEM_UNDO | IPC_NOWAIT; /* take off semaphore */
/* Recap the call to be made. */
(void) fprintf(stderr,"\nsemop:Child Calling semop(%d, &sops, %d) with:", semid, nsops);
for (j = 0; j < nsops; j++)
(void) fprintf(stderr, "\n\tsops[%d].sem_num = %d, ", j, sops[j].sem_num);
(void) fprintf(stderr, "sem_op = %d, ", sops[j].sem_op);
(void) fprintf(stderr, "sem_flg = %#o\n", sops[j].sem_flg);
/* Make the semop() call and report the results. */
if ((j = semop(semid, sops, nsops)) == -1) {
perror("semop: semop failed");
else
(void) fprintf(stderr, "\tsemop: semop returned %d\n", j);
(void) fprintf(stderr, "\n\nChild Process Taking Control of Track: %d/3 times\n", i+1);
sleep(5); /* DO Nothing for 5 seconds */
nsops = 1;
sops[0].sem_op = -1; /* Give UP COntrol of track */
sops[0].sem_flg = SEM_UNDO | IPC_NOWAIT; /* take off semaphore, asynchronous */
else
(void) fprintf(stderr, "Child Process Giving up Control of Track: %d/3 times\n", i+1);
sleep(5); /* halt process to allow parent to catch semaphor change first */
++i;
else /* parent */
{ /* pid hold id of child */
i = 0;
while (i < 3) { /* allow for 3 semaphore sets */
nsops = 2;
arent Calling semop(%d, &sops, %d) with:", semid, nsops);
else
(void) fprintf(stderr, "semop: semop returned %d\n", j);
(void) fprintf(stderr, "Parent Process Taking Control of Track: %d/3 times\n", i+1);
sleep(5); /* Do nothing for 5 seconds */
nsops = 1;
else
(void) fprintf(stderr, "Parent Process Giving up Control of Track: %d/3 times\n", i+1);
sleep(5); /* halt process to allow child to catch semaphor change first */
++i;
