What is a flip flop and its function ?
flip flop
flip flop is a data storage element that can retain the stored value ubtil next clock OR u want to change or store new data. its diferent from latch coz latch always changexs state when the data input changes but flip flop doesnt
Re: flip flop
It may help you:
http://en.wikipedia.org/wiki/Flip-flop_(electronics)
Re: flip flop
flop is a permanent storage element. One flop store maximum of one bit. flop Operations are controlled by clock.
if you want more details regarding flop mail me.
Re: flip flop
Hi Friend,
Flip Flop is a data storage device that can store only 1 bit.
Regards,
Avinash.S.
flip flop
As mentioned before. Try the Wikipedia link.
It has a very complete information about what it is, how it works, the different types of it (D, T, S-R, etc) and everything explained in a very simple way so everyone can understand it...
Re: flip flop
One bit memory storage device.
In terms of electronics circuit, u can consider it as a bistable multivibrator in which one transistor will remain in cut off i.e high output voltage and one will remain in saturation i.e. low output voltage. Untill you applied external input, it will remain in initial state.
Re: flip flop
flip flop is also called a bistable multi-vibrator. it stores one bit of data.
Re: flip flop
Flipflop is a storage device in which we can store 1 bit data. It captures the input only at the clock edge. We need to meet the setup/hold requirements, so that the operation of the flipflop will be clear otherwise the output will be unpredictable.
Re: flip flop
Here is an example of a flip-flop.
As you can see is a sequential circuit which output also depends on the last state of the circuit.
I hope it helps you
