What is a Dhrystone MIPS and how to calculate it?
123music
Junior Member level 1
What is Dhrystone MIPS?How do we calculate them?
What is the reason for using this?
Pl clarify.
Rob B
Full Member level 4
Dhrystone MIPS
It is a somewhat outdated benchmarking technique.
It was designed to test older computer systems but it may give some interesting results on modern systems if compiled and run correctly.
I think I read somewhere that Weicker thought it was now redundant.
123music
Re: Dhrystone MIPS
I am seeing the new processors performance is expressed in this.
I saw TMS570 is supporting more than 250DMIPS.
What does 250DMIPS mean?? How do we calculate that?
Rob B
Full Member level 4
Dhrystone MIPS
There is a version here:
The TMS570 documentation might explain how the DMIPS were determined.
Tahmid
Advanced Member level 5
Silicon Valley, California, USA (from Dhaka, Bangl
Dhrystone MIPS
Take a look at this:
Quoted from the above link:
MIPS isn't generally considered a useful measure of performance - it's typically quoted based on choosing the fastest (likely one of the least capable) instructions on a machine, with no regard to the capabilities of that machine. Consider, if I built a machine that could only execute NOP, but could execute 200 million NOPs a second, it would be a 200 MIPS machine, however, if I built an entire fully feature CPU that could execute only 100 million NOPs per second (and NOP was the fastest instruction) but could also execute loads, stores, adds, multiplies etc. etc., it would be a 100 MIPS machine - however, the NOP-only machine appears (using the MIPS measure) to be twice as "good" despite being useless.
DMIPS is based on the time taken to execute a particular benchmark, something which might be considered representative of a real workload, namely Dhrystone. The DMIPS figure for a given machine is the relative speed a VAX 11/780 (a particular "1 MIPS" machine) would have to run at to complete the benchmark in the same amount of time as the machine being measured. For example, if a 100MHz CPU completes the benchmark 200 times faster than the VAX 11/780 does, then it would be considered a 200 DMIPS machine. For CPUs that can be run at various frequencies, then you'll often see this value reported divided through by MHz, e.g. 2 DMIPS/MHz in this example.
Hope this helps.
Tahmid.
