What happens when antenna receives and transmits signal at the same time?
kishorekhatri
Member level 1
hi want to know that if an antena transmit and receive signal at same time ( full duplex) , then what is happening in the matel of antenna i mean if waves are received and send same time then the current also going and coming in same pasth at same time ???
dingjingfeng
Full Member level 4
question
I think the in and out frequency is different, so we can select the right signal.
the_risk_master
Advanced Member level 2
UE+MIT, Philippines, (14°N , 120°E )
Re: question
FullDuplex systems utilize their channel spectrum in a way the transmitting and receiving channels are isolated to each other thus the carrier frequency for transmission is different from reception. (correct me if Im wrong)
metu
Member level 1
question
to sepearate the signals add a circulator to the antenna or just a coupler to see the received signal
