what factors define the min frequency of the circuit?
littlefield
Junior Member level 3
What do you mean minimum frequency? there usually isn't a min frequency.
This one has me confused.
Are you meaning, the mininmum frequency you set the circuit to 'respond to' as a designer. Such as the Nyquist frequency?
Or are you talking about digital circuits switching? These will go as slow as you want.
Nothing. As ppl have said, there isn't like a min frequency. A digital design can work at as low freq as possible.
But if the system is producing a real time output , say such as mp3 decoding or video decoding, then there has to be a min freq, below which your throughput will fall to less then what is needed, and the output will no longer a video/audio you require.for example your video may become a slow-motion ;)
Hope it helps,
kr,
Avi
http://www.vlsiip.com
