What exactly is the pin to pin delay!?
vaf20
Full Member level 3
Pin to Pin delay!!!
hi
what's this exactly?
tnx
Re: Pin to Pin delay!!!
This is the propogation delay of a signal from input pin to output pin with the logic in between.
I consider your pin to pin delay belong out of the chip. If so, the delay is depent on the length of the trace, the material of your PCB and the inner or outter layer.
At very high operating frequencies the wire delays due to parasitic inductance and capacitances come into picture in addition to the logic delays.
Pin to Pin delay!!!
Pin tio Pin delay related with the chips which you used, the logic in the chip and the founction you
will realize. So different designs have different pin
to pin delays.
